So how many OEM Batteries are still Cranking??
Original/stock air in tires... all around
Still running with original battery (3/21/03) but using Battery Tender
for taking a nap. Also, 4 original tires with the original AIR!!!!
Gotta Love It!:beatnik:
122,000 on mine still orginal battery & alternator thinking about swapping them out this winter though.
MM has had a battery change, but my '95 Grand Marquis is still going...it needs to be changed soon!
98,000 miles on my 2004 OEM and no battery charger. Battery has never been dead.
Storing for the first time this year, So I'll run it for 30 minutes once a month.
03 with 55K (right now) I did change out the battery for Boston Mikes which was a sealed OEM Motorcraft battery. My origional battery was also a motorcraft but you could take off the caps to add water. I guess I should replace it this summer?
quite sure my battery is original.
Car is 04 with 25k miles,
seems to still work but reads a little low on a tester.
I am blowing a fuse under the hood as another member had stated.
It seems that this would be a less expensive route than a new alternator.
