SRP Heel Plates
fastblackmerc
Everything Marauder, LEDs & HI
Just finished painting and installing SRP's Marauder heel plates on my set on "show" floor mats.
Driver & Passenger
Drivers
Passenger
Drivers side in the car
Passenger's side in the car
They look great!
What tpy and size of mounting hardware did you use?
I have a set. am ready to install them in my MM this week end
thanks
fred
They look great!
thanks
fred
I used the hardware that came with the plates. After marking the positions, I used a hole punch to make holes so the shaft of the "T" nuts fit.
What finish did you choose, and how well is the match to your older pedals?
It appears as though you have the same pedals as I do, the one's Ladyhawk pioneered.
Both the pedals and the heel guards are the machined finish. The pedal have about 3 or 4 years of use on them. The heel guards are newly installed and will never see any use.
Done It!
Thanks for the info. did the same following your lead and am pleased with the results...then back to working on the wifes Durango!
Now stiff as a board!
fred :D
