The Bo0sted Bastard
Bezel
Not sure what shifter Zack ended up using in his race car? But he used the same boot as mine with a bezel as well IIRC.
Should help plant the car on launches. And best I could get out of the headlight.
Got the old intake off. Unfortunately my old rail won't fit the new one. I'll have to figure something out. Got the injectors packed up to get mailed and cleaned and flowed.
LOL! I was waiting to see if you replaced those OE popsicle sticks. I used the Heinous CA's and even with N/A and 4.10s it breaks the rears loose on the 1-2 even without WOT. This build thread is insane!!
The came in handy (old ones). My sister has a beat p71 (has bullet holes and all). Her arms wore out and she came to see me at work the following Monday from me swapping the arms out. Lucky her mine were still usable.
I still need the watts arms.
I did just order the tce brake lines. Still need the calipers and frt rotors to finish out that swap.
I have a shifter bezel ordered :banana2:
Got my stereo all wired and installed. Got the factory temp gauge working.
Got all the frt brake components in except tce brake lines (should be today). Got the stuff mocked up and my frt wheels don't even come close to fitting :(. Guess I'll be stepping the frts up to 20" sooner then I thought.
2019-02-02_02-05-46 by Cheapthrillb2, on Flickr
Got my tce lines in and finished test install. Just waiting on the new front wheels to come in to test fit before painting the calipers.
Working on relocating the turbo/exhaust etc. Continuing progress to clean up the engine bay... Current state...
2019-02-03_02-02-43 by Cheapthrillb2, on Flickr
Also working on relocating the radiator to under the core support instead of behind it.
I should also have my new metco watts arms Monday from mo's speed shop. That Marty sure is a great guy.
Sunday morning coffee update. Seems to be when I do it lol.
Hooked up with Marty on some new metco watts. :bows: to Marty.
Got those installed and a new pivot.
20190207_205927 by Cheapthrillb2, on Flickr
20190209_103244 by Cheapthrillb2, on Flickr
20190209_103223 by Cheapthrillb2, on Flickr
Also got the front calipers painted and installed along with tce brake lines front and rear. Question, are the 4 hose brackets at the frame supposed to be the same? Rears didn't come close to fitting. Ended up drilling a hole in each side to fit the bracket in the rear, not a big deal.
20190209_130732 by Cheapthrillb2, on Flickr
20190209_130750 by Cheapthrillb2, on Flickr hose looks funny but clears.
New wheels clear the brakes.
20190207_175934 by Cheapthrillb2, on Flickr
I found this USB port on Amazon that perfectly replaces the socket with no changes to the housing. Just need to adapt the +/- to it.
20190206_213958 by Cheapthrillb2, on Flickr
My exhaust kit came in so I've been reworking that, moving the turbo and routing the downpipe differently.
2019-02-09_02-05-50 by Cheapthrillb2, on Flickr
I gotta get the exhaust done to the trans crossmember along with a handful of other items as I need to pull the 4L80 out to get it freshened up by the end of the month. Local track opens early April weather permitting.
My dumbass installed the rear lines on the front first and bled them out, then went to the rear and realized I fawked up. The rears on the front fit pretty decent. :lol::fishslap:
2019-02-17_08-50-30 by Cheapthrillb2, on Flickr
More work underwood.
20190214_164258 by Cheapthrillb2, on Flickr
20190214_165647 by Cheapthrillb2, on Flickr
My old battery Junction box plastic was all broken up. Grabbed a clean one @ the yard. That was not fun swapping all those pins.
Turbo up and down pipes about done. Considering getting them coated by jet hot. Got the new boost referenced fuel pressure regulator installed as well. Still need to figure out what flex fuel sensor to get so I can run e85. Trans needs to come out next.
Gots the transmission out and dropped off to my guy. Figured I should freshen up the 200k junkyard unit for the coming year of abuse.
20190224_120304 by Cheapthrillb2, on Flickr
While that was out I replaced the tattered insulation on the firewall.
20190224_120509 by Cheapthrillb2, on Flickr
20190224_125218 by Cheapthrillb2, on Flickr
20190224_125701 by Cheapthrillb2, on Flickr
Also working on removing unnecessary pigtails and wiring under the hood.
20190224_135742 by Cheapthrillb2, on Flickr
I also sent my turbo pipes out to jet hot for ceramic coating.
Is it weird that I'm excited the most about the new insulation? , mine is pretty beat up lol
Sent from my SAMSUNG-SM-G930A using Tapatalk
How did I miss the insulation?
Post a link please. I hit my original with fiberglass resin to keep it together.
Looking good!
