sailsmen
Supporting Member
Good Luck with the build.
The most critical part to develop consistant power is the drive system for the S/C. Off by one washer on one pullley is all it takes to throw off the system.
Use OEM or Vortech or Procharger pulleys when you can.
I just replaced a Vortech pulley with a Procharger that had to be machined. The Procharger had 2 bearings vs the Vortech which had one bearing.
