three gauge center console pod
MM03
Member
Just thinking where I'm going to put a boost gauge once I install a supercharger. Did anyone make a 3 gauge center console pod ?
What I’m asking is rather than drilling another hole in the factory unit, Did anyone make an aftermarket unit with 3 holes angled toward the driver like the factory pod?
No, either drill the hole or do a pillar mount
I went with 2 gauges from Aeroforce, one plugs into the OBD and the other accepts whatever analog input you run to it and you can display 2 things at once. I have vacuum/boost and AFR on the analog. Kinda pricey but retains the stock look.
at first i went with autometer's single A-pillar pod then eveuntally upgraded to lo-teks 3 pod pillar. Custom made for marauders, can't beat it.
