Throttle Body upgrades
Chard
Looking for feedback on upgrading the TB to a bigger unit. Has one done it? Pro's/Cons ? HP Gains Vs Butt Dyno(throttle responce).
has one bore'd the stock unit?
I upgraded to the Accufab dual 60mm TB (stock is 55mm). The only thing I noticed is better throttle response.
It does look better than the stock unit.
You really can't bore out the stock unit because then you'll need to upgrade the butterflies.
To install an oval TB would require extensive upper intake modifications.
Neil 8uwith6 on this forum has a larger throttle body for sale that came on a engine he bought
Lmk if interested
Single
I installed the larger unit. Throttle response was greatly improved. Since I road race the car once each year at SAAC sanctioned events, coming out of the turns into the straights was improved with the new unit.
