Sarge,
I basically disaggree with your statement that gears are the only way to launch. Really I think mensrea already has more torque than street tires can apply to the pavement from 0. If you want to talk about MMs with slicks then I start to aggree that both gears and TC are needed.. In fact maybe 4.33s or 4.56s will be best with slicks and extreme output motors.
The launch benefit of a higher gear ratio and a higher stall on the TC are very similar. Both are designed to more quickly get the motor into
the power band (high torque section) of the rpm curve.
The gears help by making it mechanically easier to get to higher rpm for the same amount of vehicle acceleration.
The TC helps by allowing the rotating assembly to spin up to a certain rpm before the TC actually locks up and starts transferring torque to the
tranny. (This is the so-called FLash Stall rpm) At this higher rpm the motor is outputting FAR more torque. Torque is what makes a car go.
Now, my current TC has a flash stall somewhere around 2400-2700 rpm. It does lock up on launch but then eases back very rapidly. 2400rpm is still not a real sweet spot in our torque curve. I personally feel that a higher stall TC like 3000-3500 would really wake up our launches in a BIG way even on stock motors. Once launched the 3.55 gears now are an asset rather than an impediment.
If 60 ft times are your primary interest, having both gears and high stall TC would be idea. I'd still really like to see a comparison on mensrea's rig comparing his setup with 4.10s vs 3.55s. I think that he might have too much twist to launch optimally with 4.10s. I also would love to see his rig compared with 4.33s and slicks.
Ideally, rather than changing the rear gear ratio, we'd change 1st gear
to a lower ratio. IMHO
Now, I'm not a Mechanical Engineer. However, I did study alot of Mechanics in Engineering school (Computer engineering.)
I'm not saying TC or better than gears or anything like that. I'm just pointing out that a TC could probably achieve the same 60ft time deltas as gears (though the TC would cost more.)
To really maximize the 1/4 mile ET you'd have to model the actual tire rotations from the tree to the 1/4 and do some moderately interesting analysis. Then when you have a hypothesis, you'd probably want to
make runs and see if your theory holds up under the actual radar beam.
One thing that I must say though. My own cars biggest obstacle on the 1/4 has noting to do with the ET it's the R/T that's killing me!
I need a mod to help that!
Johnny
