The voltage drop is getting annoying, especially with lights, wipers etc. What's best way to go? Under drives or I've seen a couple higher output alternators. Any suggestions? Thanks guys.
Sent from my ADR6300 using Tapatalk 2
Maybe not even that...Mary's had underdrive pulleys on Phoebe since 2009 and she still has the same battery we bought her with in 2007. I have no idea how old it is.May slightly shorten battery life is all.
Battery tests fine, the AC draw is the worst, just noticing that it is dropping more than usual. That's why is was wondering if the under drives would free up any extra power to compensate a bit. Or maybe just a larger alternator pulley for more belt surface area? Not sure where to go with it.
it boiled down to either the computer or a wire that ran directly from the alternator to the firewall. I forget what it was called but I can take a picture to show where it is. It runs directly from the alternator connection to inside the car. They ran a new wire and voila!!!
They changed that wire and I have never had a problem since.
Here is a picture of the wire that caused me electrical headaches for over 3 years. Its the green wire that was spliced in at the alternator and re-ran. Every time I told a shop the symptoms, they all said alternator or bad grounds. Yet, it was a break inside the insulation of the previous wire that was causing all the problems.
After replacement, no more issues and its been almost 3 years.
Did a shop do that work? If so, while it may have fixed the initial problem at hand, butt connectors and wire begging to be chafed with no loom under the hood are problems that will cause other issues.
Otherwise, good find.
Again, it boiled down to that wire or the computer and I was prepared to spend the money to replace the computer if it would have solved the problem. He told me what that wire was for but I don't recall.
Thankfully they solved the problem. Replaced the wire, while although spliced, it works great and never had an issue. I have spliced may wires in my day and seldom had problems. If a problem does arise I know exactly where to look.
