Ok guys Im not the guy that was born with a wrench in his hand........... But I wanted to know is it easy to change a water pump and pulley? and if so how easy? any thing well help me before I try this on saturday!!! Thanks
It's messy, but, easy. Drain as much coolant as you can. Before you even loosen the tensioner to take the belt off, break the four bolts on the water pump pulley loose just a hair.
Thanks guys for all your help, just one last question....... Where can I get the water pump pulley and water pump from?? I have found lots of water pumps but not sure of which pully I need.
