What did you do to your car today?
Maintenance
Just completed the bi-annual (spring and fall) battery maintenance. This consists of cleaning the battery after removing it, cleaning clamps, checking connections, then charging the battery with a Battery Tender. Everyone should know how a Smart Charger works, in that it pushes the normal charge well beyond to 80% the alternator normally (or should) keeps it at. Increases capacity, CCA, cleans the plates and increases longevity. Marauder is happy. Mustang's battery hooked up at the moment.
Fire Extinguisher
Added these yesterday to Marauder, Mustang and Ranger. Hoping I never use'em but they are available if necessary. Kidde 10BC Auto-Marine Fire Extinguishers.
Had to install a new battery as the old one was crapping out on me. Started it up yesterday and had a hard time cranking up. Popped hood and could see some corrosion around the positive terminal. Cleaned it off with baking soda/water mix and a tooth brush. Leaving the house today to meet a friend for lunch and again, hard to crank up. After lunch stopped at Auto Zone and their battery tester said battery was bad. Battery was somewhere between 6 and 7 years old, so not that surprised it finally crapped out.
I did nothing but start the new engine and took pictures of it. Thanks to Marty and his crew for hooking me up with a new healthy engine. #mosspeedshop
Sent from my SM-G950U using Tapatalk
Engine bay looks nice! A bit of background would be interesting, along with some dyno numbers.:coolman:
Alright CJ! Both of us finally got our rides straight after a couple of long years...
Does this mean we’ll see more of you around now???
Thanks man and yes you will be seeing me more now that I'm bit relevant again lol
Bought it, brought it home, programed another remote, turned off the horn chirp when you lock it with the remote, and drove it!
I've had a Black 300a for a number of years but added to the collection with a DBP 300b.
I cleaned up the trunk organizer base & lids that I purchased in Louisville 3 weeks ago & installed it. Also had cleaned the battery terminals, posts & applied anti-corrosion spray on them.
