What did you do to your car today?
Un -covered its outside cover , washed her and vacc and cleaned her glass---then recovered her --and then its cousin the CV Sport-- carry on..
Finally installed my A/F gauge, 1/2 way. Waiting for mount to arrive, but it's functioning.
I do believe that is the last object I can pass through the grommet under the gas pedal!
Plug on the floor in front of the seat works best.
After a few parts issues and several days of procrastination I finnaly changed out the wiper motor in my Marauder. The old wiper motor failed because the drain was packed full of who knows what.
While I was there I replaced to aftermarket bcm with a Motorcraft version that I added a better solder to. I also put on a new belt tensioner for the 3 day old serpentine belt. Then I hand washed the car and put it back in the garage.
Detailed for a photo
Re-installed the rocker covers after repairing the paint and installing all new rocker cover clips that were either loose or falling off. 14 year old plastic can get brittle.
More work done at Mo's
After MV 14 Mo's shop installed the parts that were preordered.
Traction - LOK Limited Slip Differential w/ Carbon Discs -
31 Spline 8.8 in & 31 spline Moser axles.
New brakes & rotors
They also Ordered for the Moser studs
& a gasket for a leaky oil cooler,which they had to drain the rad to do.
Did an oil change & fix & rewire a broken Trans temp sender wire
& swap a black powder coated manifold top & Allen head bolts I brought with me.
:bows:Mo's shop rocks.:bows:
New brakes & rotors
Looking good Gordon, did you have 3.55's still? I love the black intake:bows:
As for my Marauder I just turned over 130K!
They are still 4:10s ,Just a beefier locker was installed with the 31 splines.
The car has a stronger feel in the back & hooks good.:)
But pat I only drove 4 today. Three yesterday. I want them all to feel special. I have 8.
Barry, you can host your own Marauderville. I'll come. BTW, I got my headlights sanded and polished, but thanks for the offer anyway.
It's hard to imagine EIGHT Marauders parked at your home. Your must post a picture of them all together.
You have them tucked away in a warehouse on your homestead don 't you.
Let's do lunch sometime.
Regards,
Pat
