Last update on brakes?
After burning up the pads and rotors with a desperate try at Carbotech XP8 racing brake pads (an excellent choice for track use I'm sure, but not street) I slapped a set of inexpensive Hawk HPS on without even resurfacing the rotors. There wasn't enough meat left to machine them anyway.I had to keep the car on the road until the Aero6 kit was delivered and I had modified the
correct aftermarket wheels to fit the front at 50mm offset, plus the additional consideration of a new Ford 9" axle being built for the rear.
Surprisingly, the Hawk HPS pads lasted the longest of any pad in this over-stressed combination of FNSL6R caliper and 14" X 1.1" rotor. I got 14K miles out of them and they probably would have gone a couple thousand more. So, if you are already an owner of the FNSL6R kit this may be the best way to mitigate the wear problem. Pedal feel and stopping power were not quite as powerful as the other pads, but the 4K to 9K mile maintenance intervals were ridiculous. Even with the Hawk pads the FNSL6R brakes are far more powerful than stockers.
Here is a quick phone snapshot of the new Aero 6 setup and
widened American Racing AR883 wheels. This is after 2,200 miles of use including the rainy season dirt coating. Although the camera phone shot isn't quite as detailed, I can state with confidence the wear rate is dramatically reduced. The rotor surface is close to mirror smooth, and is clearly much happier. There is no "lip" from wear on the rotor surface where the pads stop making contact towards the inner radius.
Despite the rotor diameter remaining the same, and the basic physics proving that increased pad area doesn't increase the coefficient of friction one must remember these are just fundamental laws that don't take into account the realities of over stressed materials changing properties.
The result is these brakes are significantly more powerful and easily modulated than the FNSL6R kit. Which was a lot more powerful than stock. During some brake bedding activities I applied the brakes as hard as I am likely ever to do, normal street driving just doesn't call for that behavior. The force was so great I thought my eyeballs were going to hit my sunglasses.
I noticed the ABS is very effective if the limit is exceeded, recovering traction quickly and gracefully. I have read some comments the factory ABS is wanting, and I suspect this is the same problem as the factory brakes poor performance, not a deficiency in the electro-hydraulic system.
