I'm about to order magnaflow 40's from Autoanything.com which inlet/outlet size do I need? What's best delta flow or super 40. Which outlet do I need center, offset or dual? Thanks for the help, GJTcodered
If you're just hookin' up to an otherwise stock exhaust system...do the 2 1/4...
Due to the "open-chamber" design of the Flowmasters...it's not as important on the inlet/outlet size like it is with the Magnaflows. But 2 1/4" should be doing whomever is doing the install a favor.
just my opinon, go with the super 40's you will not regret it... Got them on my MM with a bassani X-pipe, delete tips and soon to be installed Kook's headers. If not you will in the end :coolman:
I have the Flowmaster Super 40's on a complete stock exhaust system. I think they sound great, deep, and aggressive saying "Back off." In my mind, I think this would be your best choice.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
