I'd verify that you had voltage at the horn it's self when pressing the button, if it's there, and your ground is good, the horn is bad, if not, you need to start with the fuse and relay for the horn/cruise control circuit, if those are good, then the horn button itself or the clockspring are possibly the culprit.
