2014 Eaton Swap Thread Pics and Future Questions
Iac won't throw codes.
We ran into this on Mikes, but I'll be damned if I can remember what dumb brainfart move caused it. Easy fix is all I remember. All I remember was I was tired.. Zzzzz
Self proclaimed Builder Of Badassery.
Buy it, Break it, Build it BETTER.
"Since 2004"
First pic Marauder tb.
Second pic Cobra tb installed.
Third pic shows pcv setup.
The used Cobra rubber intake I bought is hard to get super tight around the throttle body. I'm starting to suspect that f***er is the cause.
What did you plug the hole on the intake that isn't used with?
"Since 2004"
TB gasket blocking the hole for the IAC? (One made for IAC delete)
"Since 2004"
IAC orientation fine. I'm not supposed to get a different one than the stock Marauder one am I? There's 2 small V shaped holes in it that aren't in the Cobra plenum.
So you do have a clear passage for air pre TB blades to the IAC, then from IAC to inlet correct?
"Since 2004"
"Since 2004"
As far as I can tell.
I refitted the rubber inlet to the throttle body and eliminated that as the culprit.
Your IAC is backwards
I saw a picture of the exploded Cobra assembly and copied the orientation from that. I know the Marauder one faced forwards. So it's backwards eh? F*** I hope that's all it is.
Another question. When I had the tstat installed backwards, the engine was likely overheating. I've heard these engines are very sensitive to it. Should I be worried?
Yes its backwards
No its fine.
Yep, the IAC was backwards. Good eye Zack!
Now that the RPM's are down, I notice that the Metco lower pulley wobbles very slightly. The main pulley is perfect, so I know I didn't bend the shaft or pulley or anything. Something to worry about? Those f***ing Metco pulley bolts were unbelievably tight and hard to crank down!
Runs great except it takes a minute for the rpm's to come down after you rev it, just like stock. I'm sure the new dyno tune will fix that, just like last time.
