2014 Eaton Swap Thread Pics and Future Questions
You're special. :bunny3:
My pedal is halfway to the floor.
Perhaps try installing your MM throttle body. I know the Cobra and ours are identical. But I though the plastic piece on the TB that the throttle cable attaches to is slightly different.
Just a thought.
Sent from The White House on taxpayers dimes.
DTR + 4.10's + Eaton swap = Wreeeeeeeeeeeeeeedom
What size fuse does the intercooler pump require? Wired it all up last night with the circuit breaker and ready to install. I was thinking 20 amp?
Nice new radiator installed.
Notice the double zip ties on the COT delete hoses. If one zip tie failed, it would be rubbed through from the belt in about 5 seconds.
I used the junction block method to terminate the battery cables and get power to the other side. I sprayed some undercoating on it to protect it from corrosion. Looks good black too.
Some pics are still downloading upside down......
A couple more progress pics.
Thanks Zack. I appreciate the tips you've given me, especially the flex EGR. It was easy with your research done.
You REALLY need to save up for a better camera..
Self proclaimed Builder Of Badassery.
Buy it, Break it, Build it BETTER.
"Since 2004"
Did you use 5/8" or 3/4" heater hose for the intercooler hoses? LMK thanks.
3/4 from bottom outlet of reservoir to the pump.
3/4 from the pump to the Heat Exchanger.
5/8 from Heat exchanger to water outlet
5/8 from water outlet to 5/8-3/4 adapter, then back to reservoir
Stock intakes can sell, don't throw them out. Someone will want them.
If you want to just get rid of them, I'll pay for the shipping to me.
"Since 2004"
I didn't notice that one pic is blurry. But yeah, camera phones still have a way to go.....
