babbage
Super Touring
im not really sure what would put me there, but heres what i was thinking:
already have a sct xcal2, currently running a zack tune, and the j-mod has been done. if i have around $1000 to work with, which probably isn't enough, but i'll try....musclemerc's cold air intake ~$420, musclemercs oil catch can $150, steeda underdrive pulleys $200. these are all parts i know i could install myself, i still have the 3.55 gears, and was thinking of 4.10's(which i can't install myself)....but i drive around 90 miles a day, and im not sure how much those gears would affect my mpg. any input would be great, thanks guys.--whitey
If you want mid 14's all you need is a new torque converter (3200 stall) cost about $750 and another $250.00 to install. That's all you need to hit 14.5's with a tune.
Reinhart has a BETTER oil catch can for about $40.00! Don't waste your money on the MM catch can. I had one and took it off as it wasn't working. (oil in the intake)
Also I think musclemerc's design of the CAI is poor, while the air might be "cold" the cfm is very poor. Uses a stock filter with less surface area than factory (frame occupies filter outer filter area) Engine is an air pump, you want a cone with greater surface area -- JLT or K&N, Reinhart one has a nice heat shield and cone filter. More CFM = more faster..
