Just ordered FRPP Shorty Ceramic Coated Headers!
Cobra catted mid pipes
Scored on a nice set of Cobra mid pipes. Looking to re-use my universal Magnaflow X and fabricate the rest in...
Getting closer:banana:
I knew all the hits would bring you some paydirt, Looks like Cali will have to pick on someone else for emmissions! Nice find, full 2 1/2" downpipes, unlike our stockers that go down to 2". Don't forget the passenger side gasket for the flat flange.
Magnaflow X-pipe - #9333
All right - last time and I will not mention it again. I really believe you are missing an opportunity to install a great hi-flow X-pipe with two hi-flow CATS that perform very well and sound great. It would work very well with your built engine. Enough said ===
Glenn Ford :flamer:
Glenn Ford :flamer:
i agree with Glenn, putting crappy stock cobra cats on seems asinine. you will probably show little to no gains. you dont think you can pass with 2 hi flow cats? maybe put 4 hi flows on?
Last Time!
Last Time - I swear I will not mention it again - promise. You can find the pipe at a better price if you search. Note: The correct number is 93335.
Glenn
http://www.americanmuscle.com/1999-2004-magnaflow-catted-xpipe.html
Magnaflow Tru-X X-Pipe (Catted, 99-04 GT and Cobra)
Item #:48026Manufacturer Info:Magnaflow 93335Market Price:$665.99 - You Save 25% ($166.00)Our price:$499.99Availability:Ships the same business day.Avg.
User Rating:
Add O2 Sensor Extension Kit:
Please selectO2 Sensor Extensions (+$39.99)Quantity:Price w/ Options:$499.99
Looking to gain horsepower but worried about failing emissions testing? Well your search stops here. This Magnaflow High-Flow catted X-Pipe is your answer to those nasty emissions inspections. Made with two high flow cats, this X-Pipe cuts down emissions, while improving flow through the exhaust, giving you more horsepower!
MagnaFlow's Mustang Catalytic Converter is designed to do two jobs: Reduce Emissions and Improve Flow. The emission reducing task is taken care of by two high-efficiency ceramic catalysts that use heat and a precious metal coating to burn off harmful elements.
Each Magnaflow Tru-X X-Pipe is made with 2.5" diameter, mandrel bent stainless steel for maximum protection and longevity. This midpipe is catted, so it can be used in states with emissions inspections.
All Magnaflow X-Pipes come with all necessary hardware for installation, as well as a lifetime warranty!
NOTE: 2004 Mustangs require the use of 24" O2 sensor plug-in extender wires!
Mid Pipe Specifications
Style Mid Pipe: Standard length "X"Type Headers Required:ShortyPiping Material:Stainless SteelPiping Size:2.5"Catalytic Converter:"Yes" - Street LegalFitment:1999-2004 Cobra and GT Mustangs
Mustang Fitment: 1999, 2000, 2001, 2002, 2003, 2004
California and Smog Legal
You guys are killing me...I did find a new set of Magnaflows Catted X Pipe for $469 shipped to me! Will need to see if CARB EO is on these...looks like a call to Magnaflow is in order then.
I have a paypal account you all can contribute to the cause...lol
My guy says the Magnaflow Catted X Pipes will pass the sniffer but will not pass the visual inspection....because a CARB EO number has to be stamped on the catalytic converters. Such is life in Cali....:mad2:
Rumor mill:
New CA state law in effect will require a smog technician to place a camera on the catalytic converter then place another camera onto the tailpipe prior to the smog test.
It make's sure the Tech is not allowing a car to pass
what the hell is that supposed to do?
They want to make sure the Tech is not going to allow a car to pass inspection unless it meets CA guidline's and hainvg a video record of each inspection keeps the process honest and make's sure the car meets CA requirments.
OK, I'm donating to the X-pipe fund
OK, give me your PayPal ID - i'm donating to the Magnflow X-pipe fund for dohc. Whose next? :help:
Glenn Ford :)
Not Certified for CA (NO Executive Order Number)
Just spoke to the Magnaflow technical support and the Catted X Pipe 93335 is not CARB Legal for use in California. No certification means no EO number stamped on the Catalytic Converters. The "ceramic bricks" that are in the casing is dipped in a chemical that cleans/filters for a specific emissions amount. 93335 meets the "federal requirement" however CA requires a higher concentration on the "ceramic brick" to be applied. According to Magnaflow the CA version X Pipe PN 93335 has been submitted but no certification has been issued to Magnaflow. Even if I purchased with no EO stamped:mad2: I would have to swap the X Pipe out every 2 years....:censor:
I think DOHC324ci is, as everyone else in Cali the exception to the rule. You got no choice move forward with the Cobra downpipes
That sucks sorry Dude!
CA is definatly a bit harsh in the laws with the emission set up's that is for sure!
Corsa DB Black Series
Well pulled the trigger on some Corsa db blacks straight through exhaust (replacing my Flowmaster 40s). Found a set used on ebay (1500 miles) for a decent price a more than half of what they retail. I am still waiting on my Cobra mid pipes...most are back East so they are balking at the price to ship $$$. Looks like another couple weeks at the earliest.
Videos of some Corsa db red (quieter of the two)
Corsa site Reference:
The ONLY muffler that delivers: MORE HP & TORQUE, A GREAT MUSCLE CAR SOUND & UP TO 4 DECIBEL DRONE REDUCTION IN THE CAR.
Mufflers specifically designed and acoustically approved for your specific vehicle.
Straight-through design means 7-10% more HP vs. stock
Premium stainless construction.
Lifetime warranty to the original owner
No stainless or wool packing material to blow out.
TWO SOUND LEVELS:
RED - Aggressive!
Aggressive With More Street Performance/Race Sound.
Recommended for: V8 vehicles only where increased power and sound are desired
Vehicles with headers and high-flow catalytic converters, or no catalytic converters
Aggressive exterior sound under throttle (esp. with headers and no cats)
Features RSC sound cancellation technology to eliminate or significantly reduce drone/resonance + O.E. quality dissipative material to "soften" higher frequency noise.
BLACK - Most Aggressive!
Most aggressive with a "wide open" sound; delivers an extreme V8 sound, both inside and out!
Recommended for:
Vehicles with stock manifolds, stock catalytic converters and/or milder engines (will deliver a great street performance sound and distinctive tone)
Very aggressive exterior sound under throttle(esp. with headers and no cats)
Features RSC sound cancellation technology to eliminate or significantly reduce drone/resonance.
Corsa db blacks PN: 8332543 2.5" offset in/out
