musclemerc
There will be caps on yours just put a small tack on them and be done
All right - last time and I will not mention it again. I really believe you are missing an opportunity to install a great hi-flow X-pipe with two hi-flow CATS that perform very well and sound great. It would work very well with your built engine. Enough said ===
Glenn Ford :flamer:
Rumor mill:
New CA state law in effect will require a smog technician to place a camera on the catalytic converter then place another camera onto the tailpipe prior to the smog test.
what the hell is that supposed to do?
Very nice! Try to reuse the stock MM studs when you get them installed. If not go with a stage 8 if your buget will allow.
Just spoke to the Magnaflow technical support and the Catted X Pipe 93335 is not CARB Legal for use in California. No certification means no EO number stamped on the Catalytic Converters. The "ceramic bricks" that are in the casing is dipped in a chemical that cleans/filters for a specific emissions amount. 93335 meets the "federal requirement" however CA requires a higher concentration on the "ceramic brick" to be applied. According to Magnaflow the CA version X Pipe PN 93335 has been submitted but no certification has been issued to Magnaflow. Even if I purchased with no EO stamped:mad2: I would have to swap the X Pipe out every 2 years....:censor:
id swap them bitches out every 2 years
