Mm starter?
O3 pharoh
The mm had a little longer cranking time the last few starts, and on my latest attempt it wont turn over. I had a 6yr old battery that was corroded so I replaced and cleaned terminals well. But still cranks and won't turn over. Also made sure shifter far enough to get neutral safety switch. Any ideas? Thanks.
Sent from my ADR6300 using Tapatalk 2
By saying cranks and won't turn over, can you hear the starter bendix engaging?
Sent from my SR-71 using Tapatalk
Is the Check Engine Light illuminated while it's cranking? If not, you have a bad CKP (crank position sensor). This will prevent the injectors from firing.
If the light IS illuminated, try pushing the accelerator pedal slightly...if it now starts, you have a bad IAC (idle air control valve).
If it STILL won't start, you may have a bad fuel pump. You should hear it run for a second or two when you first turn the key to ON (not start).
