New HID kit
I don't know anything about the 55w kit cause that's overkill for our halogen headlamp housing. I would contact the vendor about it.
Clear Plastic Ring
CtrlRaven:
The clear plastic ring in the below picture is discarded - correct and not reused?
Glenn Ford
HID bulbs are designed differently than halogen bulbs.
HID stands for High Intensity Discharge. It refers to lighting technology that relies on an electrical charge to ignite xenon gas contained in a sealed bulb. The technology of HID automotive lamps is similar to that of common vapor-filled street lamps. HID lighting doesn't have a filament but instead creates light by igniting an arc between two electrodes. HID lights get their name from the intense white light produced by the electrical discharge. HID lamps are also called xenon lamps, referring to a gas inside the lamps.
nobody can say you dont know your S:censor:T..lol...i have 6000k (crystal clear white) tops and fogs but 1 fog light went bad. gota order a pair..got mine from hidny.com
you know if you check out retro solutions web site they sell stubby H1 HID bulbs that are the same size as your factory ones. the light ball inside the light also lines up better.
but will they be the same color!? mine are 6000k a chrystal clear white but that really should be a white w/ a tint of blue!
If a bulb goes bad by the same one again or get a different kit altogether. For as much as a bulb is on some sites it would be cheaper to get a new ddmtuning.com kit lol.
got both tops and fogs working.
bright az shiznit.lol
if i had a camera and knew how to post pics i would
Sooooo....does everyone still love love these...now that i fixed the LCM I would like to install HID's this kit is so inexpensive its kinda scary....
Mine still work, I'll be ordering a pair for my DD (05 Grand Prix) and for my g/f's 08 Honda Pilot which already has projectors but uses halogen bulbs.
