fastblackmerc
Everything Marauder, LEDs & HI
Been on the fence about the bolt look vs. the recessed Allen key look. I'll try a polished one and see how I like it.
Will powder coat stick to stainless?
Yes it will. As long as the parts can hold an electrical charge, you can powder coat it.
IMHO..... In this case I wouldn't recommend it since you'll have to remove it occasionally.
The whole reason to go with a "bolt" instead of the recessed "square" drive is the bolt is easier to remove. There have been many cases where you have to end up using a pair of channel lock pliers to remove the OEM plug, because the 1/4" drive ratchet or extension broke off or you just can't get enough torque to twist the plug, which results in a ratty looking plug.
