Hi John!
When's your cutoff for getting on the F90BT order? I am trying to talk myself into one.
Thanks!
I'm in for the AVIC-F90BT (I'll also need the adapter harness for the MM and the bit to keep the steering wheel controls).
Let me know what you'll need for payment.
Thanks!
Awesome. Will the interface adaptor install plug and play?
I'm really excited about this because with my new MM I want to install something like this. To install them do you need to do any unreversible changes if you want to put the stock one back in to sell the car?
It says that MSN is required. Does this mean the GPS will never update itself? also do you have to install an antenna? Thats to bad you loose the factory sub. I was hoping to keep that and not have to add another sub.
I would definatly like to see a pic of that.
Is there any way to make the factory sub work?
MSN isn't required, but it is available. I used the radio for a little while without MSN and then activated the free 90 day trial of the MSN Direct (it's used for checking gas prices, movie times, weather, and traffic). I haven't found the MSN Direct to be overly useful.
You do have to install the GPS antenna. I despise having things stuck on my vehicle that weren't factory attached (I went as far as mounting my Speed Pass / EZ Pass transponder behind my rearview mirror in such a location that you can't see it from the driver's seat), so I have my GPS and SIRIUS antennas mounted on the back shelf behind the two bumps for the child seat latches. I ran the wires under the housing and through the hole for the 3rd brake light. I should take a picture of that and post it.
Mount the GPS antenna in the windshield/dash pinch on passenger side. Use provided metal sticky plate.
You WILL occasionally lose GPS signal mounted in back shelf when travelling due south.
I have never lost signal in 8 installs and 3 years of ownership with mount as described above.
