What a disappointment. Lost .01 of a second. Yes. Actually ran slower in the 1/4.
Picked up .162 in the 1/8th. Whoop de freekin' do!
Is something not right? There was a strong headwind all night or maybe I gained a few pounds but never would have imagined.
:mad2:
Post before and after timeslips to be able to figure out what the issue is..................
:mad2:
I bought a tune from him with a 3:55 and 4:10 option. Not sure what difference it would make besides the speedometer. I switched it over. Maybe I did something wrong. My MPH has dropped in the 1/4 but I assume that is because of the gear swap.Was your car retuned for the new gearset? In dreamland, I’m considering 4:10 gear set, 3500-3600 stall converter and CAI - keep in mind our stock engine torque peaks at 4250 rpm. The car will have to be retuned to make it all work.
I’ve had no dealings with MartyO on this board he but has many positive references here. Tell him what you have and he should be able to mail you what you need.
First pic should be fastest run before.
Second set of slips are from tonight.
Your better run a few days ago at 6:22pm, the DA was Density Altitude: 426 feet
Relative Density: 98.76 %
Your timeslip from June 24 2017, the DA was Density Altitude: 2366 feet
Relative Density: 93.26 %
Read more: http://www.dragtimes.com/da-density-altitude-calculator.php?track=6#ixzz5DPXHuWnB
OK, so something is seriously wrong with your car. It should have went much faster with the lower DA... I would ask Marty to chime in. With the above information, he will see that something is not correct. The car should have more HP with lower DA. This is the MPH at the 1/4 mile mark. Your down a few MPH.
So your lacking HP. What gasoline do you run?
Something is up... my stock car would only run 15.1.... 4.10 gears and tune she dropped to a 14.5... is your car stone stock other than the gears and tune? 14.80's on a stcok car is really quite good but that 60' time is junk...
CAI, Marty's tune, 4:10's that's it. No tire spin either.Something is up... my stock car would only run 15.1.... 4.10 gears and tune she dropped to a 14.5... is your car stone stock other than the gears and tune? 14.80's on a stcok car is really quite good but that 60' time is junk...
Thanks. I will.
"Premium fuel only"
Can you purchase E0 93 in your area?
Oh yeah. My best stock run was 14.738.Temp/Humidity can add .75 to the "best" time.
