GAMike
Curator of Speed
"the fact that someone got yelled at because they took out the garbage and took away a union job sounds like total exaggerated BS."
Blackened.... Don't know about the situation Fosters is referring too, but when I was in the hotel/convention/tradeshow business, the unions were exactely like that.....
When setting up on the show floor there was a process...
The union that layed the carpet came in, unless wires needed to be layed under the carpet... If the wire were not there 1st, the electricians union employees could not just pull back the carpet... They had to call the other union to perform the task, adding time, and an add on of a minimum number of hours regardless of if the task took 10 minutes or an hour.....
I understand the expertise in some jobs (certainly would not want my circuits and breakers installed by the guys who lay carpet
) but I think you can see this as an example of gross inefficiency adding to the cost of the event needlessly.
