Took off the master and adjusted the push rod till it sat just against the piston so I get instant response from touching the brake pedal.
QUOTE]
I did the same thing until I discovered that brake fluid gets hot and expands, then it locks up the brakes so the car hardly moves. I would recommend you back it off a little. I had to adjust it a couple times to get it just right.
I changed out the system Fluid to High temp Synthetic Brake fluid for starters to handle issues with boiling fluid and increased pressure.
But I did make sure there is no resistance between the master piston plunger and the push-rod from the brake booster when I made the adjustments originally.
But your right it is a good idea to remind people that care needs to be taken when doing this.
