What did you do to your car today?
Fuel Pump in this RV. Had to drain 25gals of fuel first!
Back to same, nothing but still hurt ! NO WAIT ! , I went to the gas station and fill the tank the “low fuel” indicator turn on
Enviado desde mi iPhone utilizando Tapatalk
Looked at it while removing the vacuum pump from my service truck. Lost power assist for the brakes backing into the driveway last night. Waiting for the rain to stop so I can finish installing the new pump.
Just bought 2 new fuel pumps, an fittings, an fuel line, Y-block, bulkhead assembly for the fuel hat to wire the pumps separately, check valve for the fuel line from the second pump and a Honeywell 5 psi pressure switch to set up my second pump up for boost activation. Started installing my KillerChiller and built brackets for my transmission cooler and fan.
Swapped out the steering wheel controls from all black to the Lincoln ones that are silver which compliments and goes well with the dot matrix.
today
I fired up the new engine, after seven months at the machine shop. New pistons, new block, redid m112 to m122, new fuel pump, new oil pump, degreed cams. Now off to the tuner.
Finally stopped raining long enough to wash a car so I started with the SB. Tomorrow JPB. Then cruise night at Lowes/Wendy's.
Got some rubber door edge guard stuff off ebay and used it on the sharp edges of the trunk lip. No more skinned knuckles! Best mod I've ever done.
Pulled some stickers off the sight shield that I thought looked good only 2 months ago. Sometimes less is more....Whatever.
PS
I miss the "other" site....:depress:
